I turn on the dishwasher with main control. I set a program then I press the on/off button. The dishwasher proceeds to fill up and after fill up it turns itself off! If I press the on/off button again, the dishwasher pumps water out, fills up again then turns itself off. I’ve tried to reset the dishwasher by pressing the program button and the on/off button for 3 seconds. No luck. Ive turned the power off and turned it on again. Same thing happens. Any clues as to the problem?:mad:
Did anyone have an answer to this?
I haven’t had the dishwasher repaired yet. I would hardly ever use it so now I don’t use it at all. It’s a real shame given its original cost and the fact it’s still pretty much new. I guess I’ll have someone come in and fix it.
Hope you find a solution.
