Arms not spinning
Tha Arms That Spray Water Are Not Turning. The Unit Is Going Thru All Cycles Please Advise:(
Check all holes in the spray arm for any clog. They all must be open.
Do you mean it fills with water, then when it’s suppose to wash it does not, then drains the water, and keeps doing this until the cycle is over…Can you hear the motor come on?
