Amana top load wadher pump will not turn off after cycle
Brand:Amana
Model Number:NTW4519JW2
Main Symptom:pump won’t turn off after cycle
What happens & when: after wash cycle finished pump turns on and have to unplug.when plugging back in pump comes back on
Try to disconnecting the pressure hose from the board and see if this stops the drain from coming on. This issue will most likely be caused by a faulty control board.
Yeah,Call Whirlpool they will probably replace it for free.They have a lot of problem with that!
service-pointer-w11766193-reve (1).pdf (718.7 KB)
