Amana side by side refrigerator side is freezing
Our refrigerator has started to freeze the food, is it due to a bad thermostat??
Measure the freezer temperature and post.
[quote=richappy;559773]Measure the freezer temperature and post.
The freezer temp is 10 degrees.
Asumming the fridg is running constantly, the freezer should be a bit colder.
Check the evaporator coils, should be entirely covered with a light frost. Also, check the condenser and condenser motor in the back
