All lights blinking
Sometimes the dishwasher works normally. Other times all the lights flash and I can’t do anything. If I power off the dishwasher I can get into the test cycle by hitting the dry air and start cancel button. Powering off the dishwasher makes it work normally somtimes. Other times I get the blinking lights I can’t do anything to make it work.
Question is do I need a new control board or control assm. Don’t want to buy both. I’m leaning more towards the control board because the buttons do work; however, it could be the control assm possibly shorting out and making the machine act crazy.
Replacement parts for FRG FDB4315LFC0 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154580201en.pdf
I am afraid it could be either device but I would lean towards the control board.
Since it is intermittent and they do not give as any pinout info on the keypad, it ends up being a crap shoot.
I would open it up and check for any moisture that may have gotten into it and then I would try try following.
Unplug the unit
Open it up
Clean the edge connector.
