After the wash cycle is finished in my top load Whirlpool washing machine, the motor continues running
Brand: Whirlpool
Model Number: WTW4816FW3
Main Symptom: motor will not turn off when cycle is finished
What happens & when: after the wash cycle is complete and the internal drum stop spinning, the motor continues running. I can only get it to stop by unplugging the machine.
If the drum and the agitator aren’t moving then that is most likely the drain pump you hear running, which might mean that there is a pressure system issue.
First thing I’d try is running a Clean Washer cycle with a couple of cups of white vinegar, that’ll remove any detergent residue that might be built up in the system and causing issues.
Thank you. That’s interesting because sometimes, especially on larger loads, not all the water drains out. Is that consistent with your diagnosis?
That could definitely be related. If the control board is getting odd pressure readings it may not drain out enough or it may run the drain pump for too long.
Thank you, again. The lights on the control board are not consistently working either. Just fyi. The unit is only 5 years old. I will try your vinegar recommendation and see what develops. If that does not fix the problem, can I continue this discussion with you at a later date?
Yup, if that doesn’t do it just come on back to this thread and we’ll go from there.
So I just plugged the washing machine back in, and that motor noise began immediately. I turned the dial to a new wash cycle to see if I could get the machine to run a cycle, but no indicator lights are showing, meaning it will not let me begin a new wash cycle. Thoughts?
That’s an emergency drain cycle.
Emergency drain should run for 6-10 minutes, allow the washer to run through this cycle. If this drain cycle is not allowed to complete then the washer will keep trying to run it until allowed to do so or the main control is replaced.
If the washer will complete the emergency drain, attempt to run a normal cycle to verify if everything is working normally now.
If the drain cycle does not complete after 6-10 minutes, disconnect the pressure hose from the main control and allow the drain to run for an additional 6-10 minutes.
If the emergency drain stops after 6-10 minutes & does not go back into emergency drain when attempting to start the next cycle w/ the pressure hose disconnected there is a physical fault in the system such as suds, blockage, drain system issue, etc.
If the emergency drain does not stop or immediately goes back into the drain when attempting to start a cycle with the pressure hose disconnected then the main control has failed.
Ok. I’ve plugged it back in and the emergency drain noise is happening. I’ve put my timer on for 10 minutes and we’ll see. I’ll get back to you if necessary. Thanks again!
