Brand:maytag
Model Number:mav7600aww
Main Symptom:not cycling properly
What happens & when:won’t cycle
Error Code (if any):none
Parts or tests already tried:none
Photos / video link:none
Brand:maytag
What is the unit doing? Will the washer just not agitate or spin? If you could tell me what exactly is going on it would be helpful.
Thanks! There’s 2 failure modes now after I installed a new motor from APP. Motor is driving the machine fine. Failure #1: Machine fills up and agitates normally, but it does so continuously for the entire 45 minutes and the tub is full of water and detergent at the end with no spinning or emptying at all. Control knob advances as normal but machine only agitates with a drum full of water the whole time. Failure Mode #2: when I twist the knob back to spin and pull it out so I can manually empty the machine the drum begins to spin and will empty, but before reaching full speed the agitator randomly actuates while the machine is still spinning. (Drum will spin and agitator actuates at the same time.) It will continue to randomly spin for a while up to a medium fast speed and then the agitator randomly agitates while it is still spinning. This sometimes brings the drum slowly to a stop, all the while it’s agitating. Then the agiatator may, or may not stop, while the drum slowly spins back up to a medium fast speed. Like it has a mind of its own, lol. I can never get a full high speed spin out of it before the agitator does its “thing.” There are NO unusual noises or smells coming from the machine at any time. Thanks for your help!
Hey guys, did you miss my last post or are the symptoms too much like a haunted house to talk about?
Does this sound like a timer or a transmission problem? Or something else possibly. Thanks in advance for any help guys.
Tech Pros, can I get your opinion on what might be going on with my washer. You asked for a detailed explanation and there it is. It’s been months and I’m still driving over to my Mom’s house to wash my clothes like its 1993 again.
