Admiral Designer Series washer - spins some during agitation; can turn drum while off
Owner’s manual says this is a Wards 6750; unit says Admiral Designer Series, 20lb capacity.
The model on the back of the unit has rubbed off to where it can’t be read; only the serial number.
While the machine is in agitate mode, the inner drums spins. This follows a short period where there was some squeeling noises during agitation.
You can also easily turn the inner drum when the machine is off.
Thanks.
Hi John,
Sounds like the transmission gone bad. Without the complete model number we not able to find the parts info. I do not think such old machine is worth the new transmission even it it’s still available.
