I have a GE profile gas cooktop model JGP963bec2bb and have to replace the top left igniter . How do I open the coo top to gainaccess to this part . Must I remove the entire cooktop from the counter or can it be accessed from the top without removing it ?
It is pretty simple with this model - just remove the burner base and pull the igniter up.
- The igniter AP6004805
Here are the breakdown diagrams and Replacement parts for GE JGP963BEC2BB | AppliancePartsPros.com
[quote=Gene;145153]It is pretty simple with this model - just remove the burner base and pull the igniter up.
Gene.[/quote]
Gene,I apologize, I amreplacing the left rear gas valve and cannot see a way to gain access to it without removing the entire cook top from the counter.
You have to remove all knobs and the burner bases. Then remove the top panel. You can see it on the diagram.
- The left rear gas valve AP6327811
[quote=Gene;145434]You have to remove all knobs and the burner bases. Then remove the top panel. You can see it on the diagram.
Gene.[/quote]
Thanks so much for your help.
