A coin was "sucked" into dryer
a coin fell into the area under the lint catcher. i couldn’t reach it and forgot about it until i started the dryer again. the dryer “sucked up” the coin and now the dryer makes a horrible loud noise. what should i do to remedy the problem? totally disassemble it?
I could not find a P02 so the following parts are for a PQ2.
Here is the parts breakdown
Replacement parts for WHIRLPOOL LEW0050PQ2 COMPACT ELECTRIC DRYER | AppliancePartsPros.com
Since you could not reach it you will probably have to disassemble the unit.
It is probably stuck in the blower.
Be sure to unplug the unit when doing this.
The following manual should help.
Whirlpool L-76 24 inch Electric Dryer Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Also whenever you have to work on a dryer it is a good idea to clean/check your vent system.
