2017 GE top-loader making an odd sound when the basket is coasting between agitations
I’ve provided a link to a video clip.
Brand:
Model Number:
Main Symptom:
Photos / video link: https://www.reddit.com/r/Appliances/comments/1o1cy8r/ge_topload_washer_makingmoaning_sounds_when/
If you can share your appliance’s model number, that’ll help narrow things down and point to the most likely cause. Based on your description, though, it sounds like the bearings may be starting to wear out or fail.
It’s a GTW685BSL0WS.
Based on the design and the noise, the bearings in the transmission are causing the noise. WH03X33731 Transmission Assembly | Genuine Ge OEM In Stock
