Brand:Whirlpool
Model Number:WZF34X18DW08
Main Symptom:It has stopped working for no apparent reason, twice.
What happens & when:One morning I discovered food melting in the freezer. The freezer was plugged in with interior light working, but not running & inside temp well above freezing. After removing food, etc. it started running & cooling a couple hours later. Ran perfectly for 6 weeks, then suddenly did the same thing. Inside temp was 28 & not running, but inside light was working. Before I had a chance to pull it out, it started working again and continues to cool. The freezer is an upright in an attached garage, sitting against an inside wall on cement floor. Since it did this 6 weeks ago I’ve put a thermometer inside & check it daily; it always around zero, give or rake a few degrees, until yesterday when it stopped again. No ice or frost buildup or obvious symptoms.
