[quote=DavidNJ;253440]This isn’t an item many dealers stock; it has long since been sold out. Broan has the parts, but that only works if you can do the repair and don’t mind having a appliance that show wear and tear (trash compactors get more abuse than anything else in a kitchen. To replace it requires thousands of dollars of cabinet work if it can even been made to fit.
This is a case where Broan should have retained at least one 12" sku.[/quote]
Sorry about all the bad news,
I have to admit, it’s been a while since I saw a 12" trash compactor.
Hopefully a good carpenter or cabinet maker can advise you in a less expensive remedy for the cabinet problem.
