C Geiger
#1 Posted : Friday, May 28, 2010 9:06:44 AM(UTC)
C Geiger
My top load washer fills with water and goes through the wash cycle. It will not spin unless the lid is lifted and closed again. Sometimes several attempts.
I suspect this is a faulty switch contoled by the lid or cover.
How do I lift the top of the washer to replace this switch?
need HELP quick.
#2 Posted : Friday, May 28, 2010 2:04:02 PM(UTC)
If it does drain but would not spin unless you open and close the lid, then the problem is a bad timer. There is a neutral stop transmission in this washer and the timer has to pause for a few seconds to switch the transmission from drain to spin.
- The timer Part number: AP3020256
