My Jenn-Air double oven beeps and has an F1 error code. I kill the power and fire it up again and it works perfectly. At about 3AM it starts beeping and F1 code appears again. Same thing two days in a row. So, I remove the two small wire harnesses and no beeps...but limited functionality....lower oven works but not top oven. So I put back one of the smaller harnesses and in 10 seconds I get the F1 and beeps. Is this the clock module or the touch panel that needs replacing. Both are expensive so it would be great to know which one is the troublemaker. :confused:
I followed the advice online and the diagnostic suggested that the clock board and not the touch pad was faulty. I ordered the part and voila....problem solved. It did take several weeks for the part to show up though, which meant three weeks of microwave meals. But this is a 13 year old oven, so I guess i feel lucky they are still making the parts. Great job AppliancePartsPro!!! :)
