I got this oven at an auction and it was previously on propane so we had to re-convert the burners to natural gas. The oven has a glow plug that works fine but the oven never lights. I didn't know how to tell if it had anything to do with being on propane. Someone told me that it was just an adjustment and I did adjust a screw or something but it didn't make any difference. You also cannot hear any gas coming in or anything. Any ideas?
Very likely the problem is a bad (weak) oven igniter (#19 on the diagram). In order to confirm it you have to measure the current drawn by the igniter while it's on. If it's 3.2 amps or less, replace the igniter. - The oven igniter Part number: AP2150412
