When replaceing this Hub Nut AP2045284, How tight do you put it back on? Do i tighten it to the point where the basket does not move or lrave it a little loose? The reason why i ask is becuase when i was taking it apart it was alittle loose but that might be the reason why it was leaking? So help please... thanks...
R/S Esteban :confused:
