wizardsbar
#1 Posted : Saturday, May 1, 2010 6:01:20 AM(UTC)
wizardsbar
Iordered new motor switch part #777971 was shipped part #780164 which is new replacement switch the switch is different than original the problem I have is the white wire it says to hookup white wire from motor and white wire from harness the unit only has 1 white wire also new switch has blue jumper wire is it ok to move this wire to lower part of terminal as blue wire from harness has larger terminal and wiil not connect to lower end
Motor switch power connector arc burnt out (Washer Repair)
by Fred_E 9/1/2016 8:05:04 AM(UTC)
Whirlpool Motor Switch 8529896 installation instructions (Washer Repair)
by supertechsappliance 8/20/2013 2:55:27 PM(UTC)
Motor switch good, but not pressed (Trash Compactor Repair)
by LeftSpin 4/22/2012 9:24:54 AM(UTC)
How to replace main drive motor switch (Washer Repair)
by Shorty 1940 2/2/2012 1:01:53 PM(UTC)
maytag motor switch (Washer Repair)
by fred1234 4/10/2011 4:12:43 PM(UTC)
dryer motor switch (Dryer Repair)
by hmort5@att.net 10/5/2010 1:09:04 PM(UTC)
dryer motor switch wiring (Dryer Repair)
by thomas e 8/14/2010 10:56:52 AM(UTC)
pump motor switching on off on off etc (Dishwasher Repair)
by chora4 5/15/2010 12:23:43 PM(UTC)
Washer motor switch re-assemble (Washer Repair)
by WindEng 10/9/2009 10:10:15 AM(UTC)
maytag washer motor switch (Washer Repair)
by happ racer 10/6/2009 2:17:28 PM(UTC)
by thombb 6/26/2009 4:37:34 AM(UTC)
Motor Switch Wiring (Dryer Repair)
by TomGJohnson 6/15/2009 5:43:42 AM(UTC)
cycle switch or motor switch fails (Washer Repair)
by andygregg 1/27/2009 1:22:51 PM(UTC)
Maytag SE1000 Motor switch (Washer Repair)
by DNyq 8/22/2008 1:27:48 PM(UTC)
Motor switch or timer? (Washer Repair)
by jakevi 3/5/2008 1:14:24 PM(UTC)
