dfriddle
#1 Posted : Saturday, June 21, 2008 6:37:00 PM(UTC)
dfriddle
I just received a new Maytag washer timer from you. It will not advance. It will fill, and then agitate or spin until I manually advance the timer.I know that my old timer was bad, it would stop completely during a cycle,until I gently pushed on the timer stem.I I have just read here on the repair forum of someone else having the same problem with a Maytag . Did I receive a bad timer? Can the timer be wired differently than my old one? The electrical pins that the timer motor connect to are in a different location on the new timer. do not know if that could be the problem.
Installed Maytag Washer Timer, now outlet short circuits (Washer Repair)
by Mjov23 10/12/2012 6:07:14 PM(UTC)
Maytag washer timer is running on and on right past off? (Washer Repair)
by Broker Dave 2/2/2011 9:48:28 AM(UTC)
Maytag washer timer (Washer Repair)
by Jeffrepair 7/26/2009 5:21:44 PM(UTC)
