I'm looking for ideas. My frigidaire washer model FTF2140CS1 is 2 years old and barely used(guest house). It just stopped spinning during the rinse cycle and now doesn't agitate or spin. The door lock switch seems to be working. There is no reed switch for the detergent drawer. It pumps water in and out, no filter clogs. Not sure if it's the timer or control board. I hear clicking like it is going through the cycles but because it doesn't spin or agitate eventually it stops and the start light flashes. Tried going into the diagonistic mode to look for error codes, but it won't work. Can't have a service person come out because I'm on a realitively sparsly populated island in the Bahamas. Thoughts? Thanks.
Was finally able to get into diagonstic mode. Error 57. Seems to be speed control board. Is that the same as motor control board? Can't find a part # for a speed control board.
