My elderly mother- in- law has a jenn-air gc50 garbage disposer that leaks from the sides where the upper and lower plastic bodies connect. It only leaks when the unit is energized and does not leak when water is flowing through it with the power off. I am not sure what gasket would correct this problem. She has very little money and I am trying to fix this for her as cheaply as possible. Any ideas?
