AmyandLouie
#1 Posted : Sunday, February 7, 2010 8:04:36 AM(UTC)
AmyandLouie
So my dad and I are trying to figure out why our dryer won't start. We've run through the list of the "usual suspects" and nothings come up.
Symptoms:
The dryer will not start. A self-diagnostic routine of the dryer indicated that the panel will light up - so it doesn't seem to be a panel issue.
We did a continuity test on the thermal fuse, and it was closed at room temperature (registered zero) --- and when we applied heat to it, it did register on the device. So that appears to be working as well.
The door switch also appears to be working. We removed it and tested that as well - it registered and appeared to be in good working condition.
We also vacuumed out the vents and the unit itself.
There is no blown fuse or tripped circuit breaker.
Any suggestions???
Thank you VERY much!!
Amy
#2 Posted : Monday, February 8, 2010 1:01:39 AM(UTC)
Replacement parts for AMANA LEA90AW Dryer - Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/RS3200005R2.pdf
This should not effect starting
[COLOR="Blue"]There is no blown fuse or tripped circuit breaker.[/COLOR]
I would still check the power in.
This is probably a long shaot as normally the Neutral to L1 power side is also used to power the board which is working.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
Unfortunately it sounds like the board is toast.
Your starting circuit is
Neutral , motor's Thermal Protect, Start and Run motor windings, motor's centrifugal Switch, H1-1 on the board, Relay K1, H1-2 on the board, Door Switch 3/1, H1-3 on the board, FS1 on the board, L1
Check for burned tracks on the board and bad connections.
Check the soldering at the K1 relay.
If you measure from H1-1 to H1-2 you should see 120 volts with the door closed.
When you push start it should drop to 0 volts.
If not either the relay is not being activated or it's contacts are toast.
