greg pezzolla
#1 Posted : Wednesday, January 20, 2010 4:05:19 PM(UTC)
greg pezzolla
Door lock keeps locking and unlocking on its own and will not cancel when cancel button on controler is pressed so i am not able to use bake cycle at all untill it stops. When it does if i set oven temp as soon as it preheat mode is reached the oven shuts down and the locking cycle starts again. Top burners are working fine. Any help before i start buying parts. Thanks
#2 Posted : Thursday, January 21, 2010 3:10:55 PM(UTC)
The first thing I would do is check the switches and motor on the latch assembly (#89 on the diagram).
Here is the Wiring sheet.
- The latch assembly Part number: AP3873473
greg pezzolla
#3 Posted : Thursday, January 21, 2010 5:42:26 PM(UTC)
greg pezzolla
Thank You Gene for your time and knowledge i will give it a try Greg
#4 Posted : Friday, January 22, 2010 1:22:57 AM(UTC)
You are welcome Greg. Keep us posted.
How to remove Superba Oven Control Panel (Oven Repair (including Ranges and Cooktops))
by gofastr 4/5/2018 10:20:54 PM(UTC)
Stovetop is working, but the oven and oven controls are not (Oven Repair (including Ranges and Cooktops))
by EgorFed 1/7/2018 7:33:15 PM(UTC)
Replaced Oven Control Board- Controls still dont work (Oven Repair (including Ranges and Cooktops))
by chuckwagon00 12/10/2017 6:48:56 PM(UTC)
GE Oven Control Board (Oven Repair (including Ranges and Cooktops))
by BillDiesel 12/5/2017 10:36:41 AM(UTC)
Oven control board? (Oven Repair (including Ranges and Cooktops))
by denverdave 4/21/2017 11:44:54 AM(UTC)
Ikea Whirlpool IBS550PWW00 In wall oven Control Thermal Fuse?? (Oven Repair (including Ranges and Cooktops))
by teamlouish 3/29/2017 6:54:29 PM(UTC)
Clock & Oven controls not working (Oven Repair (including Ranges and Cooktops))
by wfcoleman 1/2/2017 5:51:37 PM(UTC)
oven control panel not working (Oven Repair (including Ranges and Cooktops))
by nocookintoday 1/26/2016 11:04:15 PM(UTC)
Jenn Air Stove/Convection/Oven Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by moboney 12/26/2015 10:37:27 AM(UTC)
kitchenaid superba double onvection oven control touch pad (Oven Repair (including Ranges and Cooktops))
by mrE 12/6/2015 10:39:14 PM(UTC)
New Frigidaire oven Control Panel/Board - wiring help (Oven Repair (including Ranges and Cooktops))
by IGoofed 11/16/2015 11:06:12 PM(UTC)
Oven Control Quits (Oven Repair (including Ranges and Cooktops))
by FixerNot 7/16/2015 1:01:48 PM(UTC)
electolux oven control board burnt R1 (Oven Repair (including Ranges and Cooktops))
by albert13 2/26/2015 6:54:28 AM(UTC)
How to remove ribbon on oven control panel (Oven Repair (including Ranges and Cooktops))
by Fulvous3 11/18/2014 6:22:19 PM(UTC)
Magic Chef oven controller disassembly (Oven Repair (including Ranges and Cooktops))
by amnesia 11/11/2014 7:25:47 PM(UTC)
