The only thing my machine will do is agitate. No matter where I turn my dial it just starts agitating. There is no water coming in at the start of a cycle either, only agitation. No spinning....nothing. Help Please.....laundry piling up!!!:( Thanks for any help.
I cannot get your model number to come up, but sounds like a timer issue (if your machine has a timer). If it will not spin when set on spin cycle the timer (if your machine has a timer) will probably need to be replaced.
If you need more info please check the model number and post it along with whether or not it will spin.
