I bought a door lock assembly part #131888900 and it looked different in the package so I reasd what I could on the enclosed instructions prior to opening it and it appears to be an updated assembley but when I was reading the installation instructions it refers to a red wire in the 9 pin connector that should be in the 2nd position and may need to be moved to the 4th position. There is a red wire however its not in the 2nd position or the 4th position and that other wires dont match the colors on the instructions within that same plug.
