cplee
#1 Posted : Monday, January 4, 2010 4:54:47 PM(UTC)
cplee
it just quit working, it was washing,i paused it,now it wont work.I start it,it fills for two seconds stops and just hums. Any ideas?:confused:
sidfink43
#2 Posted : Wednesday, January 6, 2010 1:08:10 PM(UTC)
sidfink43
Your model is a Frigidaire sold under the Sears label. This model comes in two versions, a good version which you have which gives error codes by blinking lights.
You need to find the tech notes which should be inside the lower service panel. They will show you how to generate error codes which will diagnose your problem, unless the problem is the CCU in which case it may not be able to generate the codes. However, in that case replacing the CCU is likely the solution.
