shu7241
#1 Posted : Monday, January 4, 2010 2:21:56 PM(UTC)
shu7241
Clothes are still very wet when coming out of washer. There is no water in the bottom of tub. I checked pump and hoses and all seem OK. The washer seems to agitate OK but won't spin fast enough to get water out of clothes. The clothes aren't plastered against the side of the tub after spinning. I have a sears diagram and am fairly handy but have no experience with washers. I don't believe there is anything between tub and liner. Also can you tell me how to get the top to raise up. Thanks for any help. Bill
sidfink43
#2 Posted : Wednesday, January 6, 2010 3:52:40 PM(UTC)
sidfink43
Take off the cabinet and check the pump and hoses thoroughly. If you clothes are too wet either the drain is blocked, the pump is not working correctly or the spinning is too slow. If the spinning is too slow the clutch is a likely problem.
This site will show you how to take off the cabinet, and if you decide to replace the clutch it will show you how to do that also.
Clutch Replacement on Whirlpool and Kenmore Washers[URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=110.26882501"][/URL]
GE washer Knob/Bracket (Washer Repair)
by B.Robb Yesterday at 10:59:03 AM(UTC)
washer control panel wm2101hw (Washer Repair)
by mattessich715 11/15/2018 9:37:43 PM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 12:28:24 PM(UTC)
Maytag washer clicking noise during spin (Washer Repair)
by jeff.shields1 11/12/2018 12:21:41 PM(UTC)
dishwasher hangs in rinse cycle (Dishwasher Repair)
by REOC 11/11/2018 9:59:14 PM(UTC)
Bosh Dishwasher SHE3AR75UC/22 runs for 3 minutes, and then stops. (Dishwasher Repair)
by wcking 11/11/2018 1:57:57 PM(UTC)
bosch dishwasher only works in customer service mode (Dishwasher Repair)
by doak 11/11/2018 9:46:13 AM(UTC)
Electrolux Washer Dryer Combo (Dishwasher Repair)
by dhowe 11/10/2018 4:55:37 PM(UTC)
LG dishwasher shutting down after I select wash cycle (Dishwasher Repair)
by Jon Lamoureux 11/10/2018 1:42:42 PM(UTC)
Kenmore heavy duty extra capacity washer won't work (Washer Repair)
by petens 11/9/2018 4:44:47 PM(UTC)
Kitchen Aid Dishwasher Screech (Dishwasher Repair)
by mark.stacy@emc.com 11/5/2018 9:45:56 PM(UTC)
Dishwasher Doesn't Fill For Rinse Cycle. (Dishwasher Repair)
by JMsnh 11/5/2018 9:27:57 AM(UTC)
Bosch Dishwasher SHX68TL5UC/02 Dead (Dishwasher Repair)
by DSomers 11/4/2018 8:22:03 PM(UTC)
Frigidaire Dishwasher LGID2475QF5A i20 error code (Dishwasher Repair)
by 210matt 11/4/2018 6:32:21 PM(UTC)
maytag dishwasher will not bring in water (Dishwasher Repair)
by clarkbill 11/4/2018 6:09:42 PM(UTC)
