vornato
#1 Posted : Saturday, March 22, 2008 7:32:57 AM(UTC)
vornato
My Frigidaire washer will not spin. It agitates. But won't spin. I took the front cover panel off, and the belt is spinning on agitate, but not on spin. The belt is burnt also. The transmission was replaced 6 months ago. The seal is leaking under the agitater, leaking onto transmission from underneath on agitate and on spin cycle. I checked the motor to see if it was spinning and it is spinning on agitate with belt on, but I didn't check with belt off, I assume that since the motor is spinning on agitate it should spin on the spin cycle to. Well, not sure if it is a bad motor, a relay, timer or what. The timer goes through all the cycles, but I guess that doesn't mean it isn't bad. Well, any help would be appreciated. Thanks!
Frigidaire Washer Not Spinning (Washer Repair)
by abbaka 6/6/2011 8:01:30 AM(UTC)
frigidaire washer not spinning (Washer Repair)
by jason68 1/10/2011 11:39:49 AM(UTC)
