tmartin1065
#1 Posted : Tuesday, December 22, 2009 6:16:53 PM(UTC)
tmartin1065
The Lock on my washer will not engage. The lock mechanism is okay. I think the problem is electrical?
sidfink43
#2 Posted : Thursday, December 24, 2009 8:36:27 AM(UTC)
sidfink43
See if you can use a meter to determine if power is getting to the lock mechanism when it is supposed to. If not, trace back the wiring to see if you can find where it is at fault.
If that fails try to put the machine in a diagnosis/troubeshooting mode and see if you can generate or retrieve and error code.
Here is the service manual which will show you how. You have the "better" version of this model.
http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire washer dispenser magnet (Washer Repair)
by JAbraham 1/19/2016 12:05:33 PM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Frigidaire Washer - No agitation and no spin (Washer Repair)
by jmplsjones 6/29/2015 7:30:44 AM(UTC)
Frigidaire Washer error code 31 (Washer Repair)
by tilegods 5/1/2015 4:15:19 AM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
Frigidaire washer - loud screeching noise at start of spin cycle (Washer Repair)
by Shrimpzilla 4/8/2015 10:25:33 AM(UTC)
Frigidaire Washer "Unique" Leak? (Washer Repair)
by randynavarro 1/3/2015 7:11:35 AM(UTC)
frigidaire washer turns on by itself and floods floor (Washer Repair)
by justin r 12/31/2014 12:32:12 PM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
Frigidaire washer won't do much ... (Washer Repair)
by leahthrash@gmail.com 10/8/2014 8:10:24 AM(UTC)
Frigidaire Washer (Washer Repair)
by michelle400 8/20/2014 12:45:15 PM(UTC)
affinity frigidaire washer (Washer Repair)
by kc5tf 6/17/2014 7:29:02 AM(UTC)
Frigidaire Washer has water sitting in the bottom (Washer Repair)
by Brian84 6/14/2014 1:48:02 PM(UTC)
by MarkShannon 5/11/2014 6:02:41 AM(UTC)
