ramsfanjeff
#1 Posted : Tuesday, August 14, 2007 2:30:01 PM(UTC)
ramsfanjeff
Hello. I ordered and recieved a replacment oven controller and it has additional terminals beyond the original.
The original part (# WB27K5334) has board mounted relays with only the output terminal connections showing for Conv, Bake, and Broil.
The new replacment controller (# WB27T0204) has the three board mounted
relays also, but with all relay contact points available.
Convection relay has a Com and N/O
Bake and Broil, both have a Com, N/O , & N/C
Do I need to jumper L1 to all three relay coms?
Also, I would assume that the N/O connection is used on bake and broil w/ the N/C connection left empty. Is that correct?
Thanks,
J. Miller
