vishnefske
#1 Posted : Monday, November 23, 2009 10:03:31 AM(UTC)
vishnefske
My dishwasher seem to not be getting hot or drying the dishes. When the cycle is done all the dishes have alot of water and seems like a residue on them, I'm wondering how I would know if this just might be the heating element. I got a small part(maybe fuse) but cant seem to see where to replace it. so thought I see what my next step is. thanks shelly
#2 Posted : Monday, November 23, 2009 3:27:45 PM(UTC)
Here is your tech sheet
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
Unplug or remove power from the unit
Remove the kick plate.
Remove one wire from the heating element.
Measure the element with a meter
Should be approximately 20 ohms.
If OK
Remove one wire from the hi-limit thermostat and measure it.
Should be 0 ohms
Not sure about the above, where did you get it from?
There is a thermal fuse in the unit but it kills power to the unit.
Shelly (Washer Repair)
by JKell103 2/16/2010 2:06:43 PM(UTC)
