fraz
#1 Posted : Monday, November 23, 2009 6:36:18 AM(UTC)
fraz
on occasion I find the dishwasher timer appears stuck halfway thru the cycle and the washer running on wash but not advancing to drain. When I turn the knob to advance it seems rather hard to turn. Does a new timer seem in order or can the old one be lubricated. Once I turn it from the stuck position usually it will complete the wash and rinse and shut down.
#2 Posted : Monday, November 23, 2009 2:59:15 PM(UTC)
Replacement parts for MAYTAG DWU8260BAX | AppliancePartsPros.com
You could try opening the unit up and cleaning/lubricating it.
You really have nothing to loose.
If you are lucky it may work.
Sounds like the problem is in the gearing in the motor.
Whirlpool timer hangs up in wash cycle @ 36minutes (Dishwasher Repair)
by BRB 5/16/2008 6:56:16 AM(UTC)
