janmax731
#1 Posted : Wednesday, November 18, 2009 6:25:17 PM(UTC)
janmax731
How to remove wire connections from old latch assy and attch to new latch assy. ?
#2 Posted : Thursday, November 19, 2009 1:30:19 AM(UTC)
Here are the parts
Replacement parts for MAYTAG MDB7600AWW | AppliancePartsPros.com
The wires should pull off the switch's studs.
Often they are very tight.
Sometimes grabbing the connector with a pair of needle nose pliers and wiggling it side to side while pulling will get them off.
Sometimes using a flat blade screwdiver on the solid side of the connector and prying between it and the switch body will work.
Also remember to mark the wires so you know where they reattach.
janmax731
#3 Posted : Friday, November 20, 2009 11:25:41 AM(UTC)
janmax731
I have installed the new latch assy. Thanks for the assist.
Dishwasher Door Latch Assy - what part needs replacing? (Dishwasher Repair)
by afishe 7/27/2009 5:35:06 PM(UTC)
replaced latch assy- now won't run (Dishwasher Repair)
by Rick P 10/18/2007 2:53:26 AM(UTC)
