How to remove wire connections from old latch assy and attch to new latch assy. ?
Here are the parts Replacement parts for MAYTAG MDB7600AWW | AppliancePartsPros.comThe wires should pull off the switch's studs. Often they are very tight. Sometimes grabbing the connector with a pair of needle nose pliers and wiggling it side to side while pulling will get them off. Sometimes using a flat blade screwdiver on the solid side of the connector and prying between it and the switch body will work. Also remember to mark the wires so you know where they reattach. |
THIS FORUM IS DEAD!!!!!!! |
I have installed the new latch assy. Thanks for the assist.
