Gallexy
#1 Posted : Sunday, November 15, 2009 4:17:38 PM(UTC)
Gallexy
I haven't had any problems with this dishwasher till now, I have had it for 3+ years and Finally a small problem :(. So My drain is clogged and I dont know how to drain it. If I pull it out from the wall how am I going to get the water out. Manually draining is just making a sound and is not draining out. Please if you know of an easy way please help me out. :confused:
#2 Posted : Monday, November 16, 2009 2:50:18 AM(UTC)
Undo the drain at the house plumbing. If you are lucky this is where the plug is.
If not empty it with a cup, then use a sponge or a turkey baster to get what remains out.
There will still be some water in the system when you disconnect the drain at the unit so use a shallow pan to catch it.
Gallexy
#3 Posted : Monday, November 16, 2009 4:36:50 AM(UTC)
Gallexy
boo, lol thank you. I will do today and let you know how it all works out. Again Thank you!
Gallexy
#4 Posted : Wednesday, November 18, 2009 6:58:31 AM(UTC)
Gallexy
Got everything working thank you. Drain plug and plu at bottom of strainer was clogged with little balls that looked like pearls (was not obviously) but still had to think it! But all works great thank you again!
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner II DU1145 (Dishwasher Repair)
by Guest 3/25/2021 6:39:10 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner II Model DU1055XTVQ8 (Dishwasher Repair)
by mgandhd 4/29/2020 9:16:12 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
Belarus WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet Partner II (Dishwasher Repair)
by dresstheman 12/30/2017 5:17:12 PM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool quiet partner ii won't start (Dishwasher Repair)
by Mac m 1/6/2015 5:53:21 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by mgmills 6/8/2014 7:58:45 AM(UTC)
