im getting a ''PF'' code on my oven. this has been going on for a while now. i've attempted various ways to get it working with no luck. my control board does not respond when trying to operate oven. the clock and top burners work but nothing else. can someone please help!!
Unplug the unit and access the board to inspect for any evidence of component damage (like a burnt or discolored resistor). If there is, replace the control. If not, check the power at the outlet. If you have 120VAC at the outlet, you probably need to replace the board. Try powering it back up after about ten minutes, or more, after it was unplugged. If the error code doesn't go away, you probably have a bad board. I believe it's a complete assembly.
