BONN96
#1 Posted : Saturday, November 14, 2009 8:22:52 AM(UTC)
BONN96
LOVE MY MAYTAG IT STARTS TO DRAG WHEN AGITATE THEN SOMETHING SMOKING . HAVE NEW MOTOR , SWITCH OK , NEW BELTS , IS IT TRANMISSION OR SOMETHING TO DO WITH AGITATOR:confused:
sidfink43
#2 Posted : Sunday, November 15, 2009 9:10:43 AM(UTC)
sidfink43
Hopefully the problem is something jamming or obstructing the pump, so I would remove the pump and see if it turns freely. If there is a problem, replace or clean it out and you should be fine. Here is the service manual for your machine, and getting to the pump is not difficult.
http://www.servicematters.com/m...6010373%20(16001145).pdf
If it is not the pump then am afraid the other possibilities, including the transmission are such that you will want to replace the machine rather than try to fix it.
Good luck.
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 11:11:57 PM(UTC)
washer fills but will not agitate, will spin and drain (Washer Repair)
by antiquepem 9/12/2017 12:53:24 PM(UTC)
Replaced the bearings and seal now will not agitate (Washer Repair)
by Lamb3 2/6/2017 4:55:34 PM(UTC)
kenmore washer will not agitate (Washer Repair)
by crawdadcreek 7/29/2015 1:07:27 PM(UTC)
by lizardking508 6/21/2015 3:00:22 PM(UTC)
Will not agitate but does spin (Washer Repair)
by domcrews 4/27/2015 2:30:07 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 7:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 11:51:44 PM(UTC)
Washer will not agitate (Washer Repair)
by jemiller33 11/25/2014 7:02:02 PM(UTC)
Washer will not agitate, or spin (Washer Repair)
by win809doo 5/19/2014 11:19:45 AM(UTC)
Washer will not agitate, spin, or drain (Washer Repair)
by nosinina 4/16/2014 11:42:37 AM(UTC)
Maytag will not agitate (Washer Repair)
by 1hkfan 4/6/2014 12:15:38 PM(UTC)
Washer will not agitate, but does spin. (Washer Repair)
by Kas23 3/18/2014 5:50:05 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 11:16:38 AM(UTC)
Kitchen Aid turns on but will not agitate or spin (Washer Repair)
by LTuttle 12/28/2013 5:23:34 PM(UTC)
