Ignitor is intermittent
Will come on....gas valve opens....cylcles great ignitor off....does not come back on but motor is running. Cleaned all vents....very nasty tested all components,fuse, thermostat,coils,ignitor,ignitor sensor everything checked ok. replaced coils,ignitor,ignitor sensor and dryer dried one load now dryer is doing it's cycle mentioned above again. I guess my next step and the only one I can think of is the timer? If so how do you check? Or the gas valve? I didn't check voltage to coils.....
Thanks.... e31430
