covehome
#1 Posted : Thursday, November 12, 2009 6:27:17 AM(UTC)
covehome
The light for the door lock is the only thing that lights up on the control panel. When pushing any option buttons, it flashes, but the option and the cycle buttons do not light up, change or start. All the connections are intact with no sign of damage. Any suggestions on which part to replace? Thanks.
#2 Posted : Thursday, November 12, 2009 7:39:59 AM(UTC)
Your model number is missing the last digit.
Also I think it is KUDI01ILB?
Note the use of 1, I and L the people at Kitchen Aide seem to enjoy confusing everybody.
Here is a tech sheet. It is for a KUDI01ILB0 so am not sure if it will match your unit
http://www.servicematters.com/d...0Sheet%20-%208530866.pdf
If by door lock you mean control lock then perhaps it just needs resetting.
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Replace the main control panel? (Microwave Repair)
by Guest 10/25/2021 7:11:40 AM(UTC)
line voltage in old Whirlpool control panel? (Dishwasher Repair)
by Paul_illinois 2/19/2014 7:40:06 AM(UTC)
Can I test a Control Panel? (Oven Repair (including Ranges and Cooktops))
by opeter 11/6/2013 9:27:43 AM(UTC)
Is it bad that there is debris under my control panel? (Dishwasher Repair)
by abahan 8/22/2013 2:18:18 PM(UTC)
I fixed one problem, but did I fry control panel? (Oven Repair (including Ranges and Cooktops))
by friendly_jacek 12/15/2012 7:04:22 PM(UTC)
Maytag Dishwasher quietseries 200 control panel? (Dishwasher Repair)
by Maytagwhat? 12/12/2012 6:52:42 PM(UTC)
Element or control panel? (Oven Repair (including Ranges and Cooktops))
by gettmac 1/23/2012 2:50:03 PM(UTC)
Control Panel? (Washer Repair)
by Sutherland 11/28/2011 11:47:24 AM(UTC)
Maytag won't fill. Valve or Control panel? (Dishwasher Repair)
by tdfaber 10/1/2011 1:21:37 PM(UTC)
How do I replace the electronic control panel? (Washer Repair)
by AWC 9/7/2011 9:12:30 AM(UTC)
Replace control panel? (Dishwasher Repair)
by merple 6/8/2011 10:41:51 AM(UTC)
Control board or control panel? (Oven Repair (including Ranges and Cooktops))
by Julie0012 5/19/2011 6:00:45 AM(UTC)
control panel? (Dryer Repair)
by guyfino 2/4/2011 7:35:28 AM(UTC)
Kitchenaid Dw: Need New Control Panel? (Dishwasher Repair)
by chipLAT8706 11/5/2010 12:31:07 PM(UTC)
