tomii
#1 Posted : Tuesday, November 10, 2009 5:37:50 PM(UTC)
tomii
I have a whirlpool dishwasher. It quit working today. I just took it apart, and I can see that the impeller blades are all missing. I can't tell if they were knocked off, or eaten away. There seem to be no pieces floating around inside, and the motor is working.
No leaks.
So, I see that impellers are only, like, $20.
2 questions:
1) How do I get the darned thing off the motor shaft?
2) I see the impellers (PN: 3108052) are out of stock - how soon can they be delivered if I order now?
3) (I can't count) - what else should I get to ensure the repair is good?
tomii
#2 Posted : Tuesday, November 10, 2009 5:42:30 PM(UTC)
tomii
Got it off. Didn't break anything. Still - how long to get a new one? And what do you suppose happened to it?
#3 Posted : Wednesday, November 11, 2009 2:12:45 AM(UTC)
This is just a forum sponsored by AppliancePartsPros, you should email or phone them for an ETA on the parts you need.
I was looking for info for you but could not find anything decent on pump repair but perhaps the following will be of some use.
https://secured.whirlpoo...510938/$FILE/4322430.pdf
As to what happened I can only guess. Something could have got in there, ate up the fins and then once they were gone was able to get out.
I would check the drain assembly just in case it is now stuck in there.
