Need Help installing Washing Machine Timer
Take out the two screws in the back that hold the end caps to the cabinet. You can then flip up the console and get to the timer. There should be instructions emossed on the back of the time, but if not, just push in the knob, pull out the tab on the back, take off the knob and the dial and you can access the screw that holds the timer to the console.
