The dishwasher detergent dispenser cup won't close. I've taken off the door panel and see that the Timer Lever Spring is connected to the Detergent Timer Lever, but isn't connected to anything on the other end. What is the other end of the spring supposed to connect to? I have the diagram with part numbers, if that helps you describe, but a diagram would be most helpful.
THIS FORUM IS DEAD!!!!!!! |
