I checked for continuity, good. I can hear the motor try to go. I tried to turn the shaft from the inside by spinning the cutter head, as I see nothing else, it turns but feels like it catches, is there a way to get inside without removing the motor, if not are there some tips for doing this?
See page 22 in the manual |
THIS FORUM IS DEAD!!!!!!! |
