During the wash cycle I would get an F3E2 fault. I checked the code and says it is a temp sensor fault. Being a technician I measured the resistance of the wire going from the sensor to the TH2 connection. Even while wiggling the wire I still got low resistance readings. Since the sensor was only $8 I started with that. After installing the sensor I ran the washer, it passed the wash cycle and I figured it was good, but it now faulted with the F3E2 code during the final spin cycle. Is there anything else that could cause that code besides the control board?
