Have a Whirlpool Gold oven, model number RBS275PRB00. It is throwing two different error codes, E2-F3 and E1-F5. The first points to the oven being too hot during the bake cycle, and the second one to the latch system (we dont run the auto clean after it fried the small thing on the back of the unit, dont remember the name). I checked the OHMs between the temp probes terminals and got 1091. All the wires looked ok. The only thing i can see wrong is the big red wire that runs from the control board to the fan, the plastic around it looks like it got too hot. We have already replaced the control board once before years ago.
The Sears Parts Direct site says if the OHMs are not 1080 than the probe is bad, is 1091 too high? Any help would be appreciated.
