frosini
#1 Posted : Monday, October 1, 2018 7:23:00 AM(UTC)
frosini
Hello,
My KitchenAid electric oven is over 10 years old, and I had already replaced the control board. Now when starting the oven the control panel lights up, but when I set the function and temperature- No Heat! No bake, no broil, no roast, no convection heat. Have not recently run clean cycle.
Any suggestions where to start?
Thank you,
/Peter F.
ohm
#2 Posted : Monday, October 1, 2018 7:32:46 AM(UTC)
ohm
Was thanked: 3 time(s) in 3 post(s)
Can give you your tech sheet.
File Attachment(s):
KEBC107KSS04 Tech Sheet - 8302067.pdf (317kb) downloaded 1 time(s).
Repair Part List - 8186239 - Rev A.pdf (331kb) downloaded 1 time(s).
You cannot view/download attachments. Try to login or register.
ohm
#3 Posted : Monday, October 1, 2018 7:38:45 AM(UTC)
ohm
Did you Programming the Cavity Size or board after installing it like is says in the tech sheet?
frosini
#4 Posted : Monday, October 1, 2018 7:45:03 AM(UTC)
frosini
Thank you for this reply. Can I power the oven off/on then perform the board programming as described in the tech sheet?
/Peter F.
frosini
#5 Posted : Monday, October 1, 2018 8:22:51 AM(UTC)
frosini
I cycled the power off/on then programmed the control board. Still no heat. What is next step: Thermal fuse or temp. sensor?
To be clear, I replaced the oven control board several months ago after erratic oven operation, and it has been working great until now.
TY!
/Peter F.
Billy889
#6 Posted : Monday, October 1, 2018 4:41:03 PM(UTC)
Billy889
+1
UserPostedImage
