So I acquired this French door LG refrigerator and I got in pieces So I got it all back together and plugged it in and it appears to run just fine. Then I noticed that the bottom freezer door was not closing tight at the bottom in fact there was a gap of about 3/8’s of an inch at the bottom. Now this door is a tilting door and seems to operate normally. I checked for adjustments of some kind but I don’t see any. I’ve scoured the LG web site but with no luck and also the internet but no real solid info there either. Had anybody experienced this problem? If so what was the fix? Any info would be greatly appreciated!
