I have a 2 year old whirlpool washer (WTW5000DW1), that will not fully drain. I have already cleared all drain hoses of all debris. I have taken the pump off and ran it manually (it works fine). I have taken the inner tub out to check for obstructions between the inner tub, and outer tub- and found nothing. I even changed the clutch assembly because I thought it may not be spinning efficiently. It is still leaving my clothes soaking wet. Any ideas?
