The top load washer will not agitate or spin. The motor is showing a Lid Switch error code. In Field Service Mode there were no error codes, not even for the lid switch.
GE Profile Model Number: PTWN6250M0WT and Control Board number: 175D2750G377
I took out the Lid Switch and checked it with my digital ohm meter. With the magnet, the resistance was fluctuating but it hit zero and beeper a few times.
Is that a sign of a bad switch?
When I checked it at the Control Board I got 13vdc between the Blue and Red wire and a pulsing .65 to .75vdc between the Red and Yellow wire. Is this good?
I disconnected the communication harness at the Motor and checked the Motor harness connector for the same voltages found at the Control Board. I got 13vdc between the Blue and Red wire and a pulsing .65 to .75vdc between the Red and Yellow wire. Same as the control board. Is this good?
No Field Service error codes. The motor had normal red flash 1sec on/off most of the times. Sometimes when disconnecting thins, I have seen the motor blinked 10 times and pause.
Thanks for taking the time to help me figure this out. I really appreciate this.
- KJ
