also double line on status--goes off and on by pushing cancel/drain button..., NOTHING ELSE WORKS.
Cold reboot: Tried turning off power for 5 minutes--no change
Cycle rest: press and hold Cancel Drain button--no work
Alternately pushing two buttons to reset control panel--no change
check continuity of fuse = OK
Unplugged control panel ribbon and no change
Please provide tech data sheet (usually in kick panel) plus electrical checks for 8269199 control ribbon; RLRIDLJA Barcode motherboard; 8530909 Whirlpool part number and 3090900277629
